Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
iPhone 5c time issue (time doesn't change)
Hey hopping someone can help, I recently got a iphone 5c that was dead, I replaced the battery and the screen and i got it working again. The problem is the time doesn't set automatically even though the setting is on and when I lock the screen the time stops counting.
Can anyone help?
UPDATE
Hey so I have noticed that the time changes when the battery is charging but stops as soon as the battery is 100%. Could this be a battery issue?
Is dit een goede vraag?
5 opmerkingen
Have you connected it to wifi?
door
yes and I have tried to do it manually
door
My dear friend you need to turn on locations then plug in with itune time will be reset automatically if not then restore your device time and date will be ok if you still getting same problem then put compass ic . thats it job done
door
Hey so I tried what you said still didn't work although now the time works but only if I have the phone connected to my pc
door
my friend you need to change compass ic then micro soldring
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
There is a crystal oscillator (Y2) on the board which can fail which can cause this problem. It's something which can be replaced. Requires micro soldering.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
Would this be a costly repair?
door
Funnily enough this issue I have only seen it happen on iPhone 5C the most common which is weird.
door
Not too costly Dmtech94. You'd need to check with someone in your area.
door
I have the exact same problem as you except that mine crashes my phone when I try to get into date and time
Voeg je antwoord toe
Dmtech94 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 1,441
