Ga door naar hoofdinhoud
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Vragen Bekijk alle
Intel iMac as an external monitor - Guide
I had a 2006 Intel iMac that died (logic board / graphics card failure) and instead of consigning it to the bin, I aimed to turn it both an external monitor for my screen-less 2009 MacBook Pro (LCD driver failure, failing battery) and any HDMI device I wanted. I had seen this done with G5 iMacs, but never with Intel ones, which use different display types, so decided to have a go and was successful!
My guide can be found in the answer...
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Guide of how I did it - http://www.instructables.com/id/Intel-IM...
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
@moomike - Michael - Sadly all of your work here won't be found if you just post it here. The best thing to do is create a IFIXIT guide that way someone who also wants to do the same thing can find your efforts. Follow this link: Create an IFIXIT Guide
door
Voeg je antwoord toe
Michael zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 225
