Battery draining very fast (low number of cycles)
Hi all
I bought a second handed MacBook pro 15" mid 2010 - the battery was renewed just before my purchase.
Battery type is TOP A1321, it only has 221 cycles and it has the OS X Battery status "Good".
More info about the battery is here: http://oi66.tinypic.com/2lo3dyb.jpg (using the coconutBattery tool)
I am working in the IT industry so I always charged my battery the way it should be (always pulling out charger when fully charged, etc etc..)
I've checked my Activity and there are no processes with extreme high CPU % usage..
I am using OSX Yosemite (10.10.5) - could that cause the problem? Should I try to downgrade?
Stil, my battery is draining fast, very fast - when fully charged I think my battery only lasts for bout 45 min - 1 hour.
For a laptop this is far from ideal so I would like to fix it..
Thanks for advices!
Is dit een goede vraag?
4 opmerkingen
Can you explain what you are doing on your system, web browsing, gaming writing of some sort?
Have you looked at Activity Monitor to see if something is running in background (malware or peer sharing)?
door Dan
Hi @danj - first of all thanks for your comment.
Most of the time I just use my Macbook for web browsing (reading articles, facebook, etc) - so no heavy gaming or any usage of my 8GB and i7 processor.
I did check the Activity Monitor, but I don't find anything suspicious (with high % usage).
Is it possible there is something running on low % CPU usage but with high battery usage?
Thanks in advance.
door Nic
Given the rate of discharge I would have expected something standing out in Activity Monitor.
You could try creating an external bootable disk (USB thumb drive) to see if it runs longer under a clean OS. I wouldn't touch your internal until your sure it runs better off of the external. Keep in mind your system will be slower! As the USB I/O is not as fast as the internal SATA port. This is only to see if the there is something going on within the OS.
door Dan
@danj I created a ubuntu live cd and when "testing" ubuntu the battery is stil draining very fast.. From 90% to 50% in +/- half an hour.
So I guess it isn't OS related but battery related?
door Nic
