Ga door naar hoofdinhoud
Mr. Potato Head is een Amerikaans speelgoedfiguur dat bestaat uit een plastic aardappelmodel dat versierd kan worden met diverse plastic onderdelen die aan het hoofdgedeelte kunnen worden bevestigd.
Grinding sound won't move
My Toy Story Collection talking mr potato won't move his legs like it's supposed to and is making a grinding sound how to fix it
Is dit een goede vraag?
Score 2
1 Opmerking
Please let me know how you fixed it ???
door
Voeg een opmerking toe
6 Antwoorden
Het nuttigste antwoord
  1. The Real Mr. Potato has no moving Parts. He doesn't move either, at least on his own.
  1. Open up Mr. Potato's back and dump out the innards.
# Have fun!
Was dit antwoord nuttig?
Score 1
Gearbox gear repair.
It seems to be a fundamental problem for the product.
All the problematic products are the same gear problem.
The two gears in question must be repaired by opening the gearbox.
It would be easy to get the same gear, but...
A gear is cracked.
The thickness of the steel pipe in the middle is larger than the gear hole, resulting in a crack.
Secure the cracked gear with glue and expand the hole.
Grind steel pipes to make the hunger thin.
https://youtu.be/4QJFvA5n3gs
업데이트 (2019년 10월 23일)
The cracked side of the gear needs to be cut and glued. This ensures a constant gap between the teeth.
Afbeelding
The gears were first disconnected and then polished the bumpy part of the metal pin.Cut off the cracked part a little and fix it with a force adhesive. Apply a little glue to the metal pins and fasten them with the gears.
Score 1
6 opmerkingen:
Do you have a diagram of how the gears fit together?
door
@weirdalfan1 No, i have not. Cut off the cracked part of the gear. Because it is to fit each gap in the gears. This is important.
door
Hi there please can you help me. My mr potato head is also broken. He talks but does not wobble. Could you maybe do a step for step guide with photos on how to fix him..... im part of a toy story collection group on facebook and it seems to be a regular problem. If you could do that im sure you would help allot of people we all struggling.please please pretty please. I love my mr potato head and so badly want to fix him i have spent days trying to figure it out but havnt come right. :(
door
The repaired product was not mine. The repair process was complicated, so I didn't take many picturesI'll organize and let you know the photos I took at the time. If you ever visit Korea, I will help you.
door
@Antoinette Botha The repaired product was not mine. The repair process was complicated, so I didn't take many picturesI'll organize and let you know the photos I took at the time. If you ever visit Korea, I will help you.
door
1 commentaar meer tonen
Step-by-Step Fix
  1. Disassembly: Document each component’s position and assembly order with photos.
  2. Gear replacement: Swap the damaged gears with precision-matched custom gears.
  3. Lubrication: Apply silicone-based grease to all moving parts.
  4. Reassembly: Reverse the disassembly sequence strictly.
Afbeelding
Afbeelding
Afbeelding
Simply using glue to repair a broken gear often doesn’t work. Initially, I tried that approach too, but the result was that it still jammed. Because the gears in Mr. Potato Head are very precision-engineered, I ended up repairing it successfully by replacing the gears with custom-made ones
Score 1
Hi hi, i wanted to find out did you manage to fix your mr potato head? Mine is doing the same thing…he speaks but no longer wobbles. Please help. It must be the gears … i glued the 2 cracked gears but when i put him back together he still doesnt work.
1 Opmerking:
door
Hello, thank you very much for your help, but the problem is that when I opened the gearbox one of them came loose and I don't know where to put it. I have included photographs with the gear
1 Opmerking:
I don't see the picture you sent. Maybe you should check—there's no gear image.
door
I have same problem and wonder where you obtained the replacement gears
1 Opmerking:
I modified some but on Amazon there is an assortment of platic gears for toys. There are like 75 in a pack for under 8 USD
door
Voeg je antwoord toe
Dillon Bieber zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 60
Altijd: 3,013
