Ga door naar hoofdinhoud
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Vragen Bekijk alle
820-3476 No Backlight but image is there
Answering the usual questions:
Do you have 2.7v to 3v enable signal on pin 17 of U7700? YES 3.3v
Do you have 5v on pins 5 and 18 of U7700? >> YES
R7733 0 ohms? >>>> YES
What voltage do you have on backlight output, pin 1 of LCD connector? 0v? 12v? 20v? 27v? >>> 0v
Is dit een goede vraag?
Score 1
18 opmerkingen
Pins 3 and 4 of Q7700 are the same voltage, 12.6V so all voltages after Q7700 are 0V.
door
@pollywaffle did you rule out bad screen first?
door
I actually plugged in a same year 15 inch retina lcd and it behaved the same, image viewable with a light behind the apple, but no backlight.
door
sorry , i cant help you with your problem, but i have a similar problem with Intel Core 2 Duo 2008 and maybe my problems can helping you solving yours :).
I replaced all the i wrote that can help fix the problem (inverter cable, inverter board, logic board), but its still not working. when the screen turns black I can use the dim key back to zero and then again forward and sometime it works and the screen light up again, but not everytime, sometimes it only flare up a bit and then turn off again
door
What about a PPVIN_S0SW_LCDBKLT shorted to ground?
This would lead to a high current through R7700, detected by both U7700 and U5450.
Can you run the AHT and see if U5450 raises an error?
door
13 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Check voltage on pin 2 of pull up resistors for i2c_bklt_sda and i2c_bklt_scl. Should both be 5v. If not 5v, test resistance of pull ups 2.4Kohms. If those readings are good, check the trace continuity from pull up resistors to connector.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Bill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,219
