Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Vragen Bekijk alle
Vraag afgerond
Is that problem with anti-glare layer on Retina screens still there?
Hello everybody!
I'm planning to buy a Macbook Pro 15'' (2015) MJLT2. But after I made a research about it I found a lot of negative responses about a problem with an anti-glare layers. It seems that this issue is peculiar to MBPr's from 2012 to 2014.
Some guys even created a website to show Apple how global that problem is:
http://www.staingate.org/
So my question is: Is that problem with anti-glare layer on Retina screens still there, for Macbook Pro Retina (2015)? Or is it solved in the newest Macbooks, starting from 2015?
I would appreciate any help or tips. Thank you all in advance! :)
Best regards, Optimix
Is dit een goede vraag?
2 opmerkingen
I wonder if a tempered glass screen protector would alleviate this issue.
door
Thank you for the answer :)
Hmmm... maybe it's a good idea. Guys, anyone used some kind of slass protectors on Retina displays?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
short answer yes the problem is still around on 2015 models but apple are offering a free replacement screen on all affected models as long as it has been reported to apple within 3 years of purchase.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you for a prompt answer!
As I heared this Quality program from Apple will end on October, 2016. And it would be really bad to stuck with this problem in 6-7 months of using the Macbook Pro.
Darn... After your words I really don't know if it's a good idea of buying a Pro version :(
door
i would suggest contacting apple about the quality program as it shouldn't end so soon
but if you are buying new you should not get a faulty laptop as apple will have hopefully removed the faulty screen from production.
door
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 871
