Ga door naar hoofdinhoud
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
Where is the fuel filter?
location of fuel filter?
Is dit een goede vraag?
Score 2
2 opmerkingen
gas or diesel ?
door
Thanks for the help.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Depending on the year of the truck if its gas or diesel there are several locations . On the diesel its located next to the master brake cylinder. On older gas models its mounted on top of the fuel tank next to the sender unit on some of the newer models its mounted to the frame rail next to the fuel tank . Easiest way to find it is to start at the fuel tank sender unit and follow the fuel lines to the engine. you'll find it in there somewhere. If your not seeing it odds are its one of the ones mounted on top of the fuel tank. Hope this helps
Was dit antwoord nuttig?
Score 5
Voeg je antwoord toe
Terry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 113
Altijd: 26,837
