Ga door naar hoofdinhoud
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Vragen Bekijk alle
P5 pentalobe and 1.2 pentalobe screwdriver
Hello,
I am sorry if this is not the correct category for my question but I do not know where else I can ask this.
I am looking for a P5 pentalobe screwdriver because I have to do some fixing on my MBP. In my country it seems there is not P5 pentalobe screwdriver but googling I found out that P5 pentalobe screwdriver's dimension is 1.2 mm; so my question is: is a 1.2 mm pentalobe screwdriver and a P5 pentalobe screwdriver the same?
Thanks.
-C
Is dit een goede vraag?
Score 5
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
P sizes TS sizes PL sizes[11] Dimension Usage
P1 TS0 Unknown
P2 TS1 PL1 0.8 mm iPhone 4 (Late), 4S, 5, 5C, 5S, 6, 6 Plus, 6S, 6S Plus
P3 TS2 Unknoen
PL2 0.9 mm Apple Watch Band
P4 TS3 Unknown
PL3 1.1 mm
P5 TS4 PL4 1.2 mm MacBook Air and MacBook Pro with Retina Display
P6 TS5 PL5 1.5 mm MacBook Pro (2009) Battery - 15” only. Also known as Apple specialty tool 922-9101
PL6 1.6 mm
Was dit antwoord nuttig?
Score 17
1 Opmerking:
P5 screwdriver is as the same as 1.2 .You are correct. Had the similar issues before and 1.2 worked for me .Ho fir it
door
Voeg je antwoord toe
Carlos zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 78
Altijd: 27,844
