Ga door naar hoofdinhoud
Repair and disassembly guides for garage door openers.
16 Vragen Bekijk alle
Jerking upon opening garage initially
Lately, when I go to open my garage door, it jerks and then stops. I have to then close it and start again to open it. What could cause it to do this?
Is dit een goede vraag?
1 Opmerking
@mactechplus thought you might have some advice on this one.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The rollers on the side are binding in the tracks. Track bent? Roller bent?
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks, will have to check if they are bent.
door
Check the rollers on each side, make sure the are not crooked, binding, or other wise. Often the tracks that they run in can get a little tweeted, and this can cause issues, especially where the two pieces meet. Could be binding there.
If your door still has a manual lock on it, sometimes the bar can catch on the track as it passes through the curve.
Voeg je antwoord toe
Wendy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 4,151
