Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Vraag afgerond
iPhone will not hold a charge.
My iphone stop charging so I replaced the charging port. It turns on but when i unlock it its not charging and then after about 10 15 minutes it shuts back down. (All the while being plugged in) Do you think its the battery or is it the new charging port?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
it might be the battery is it jailbroken?? try replacing the battery and c if that helps.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,744
