Ga door naar hoofdinhoud
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
90 Vragen Bekijk alle
Vraag afgerond
Need help to fix Xbox 360 Controller analog high sensitivity
I have an original wired Xbox 360 controller for windows which is broken. So, I've bought a wireless controller + a wireless receiver for windows. The analog sensitivity of the wireless controller is very high whereas the original wired i that have, the sensitivity is perfect. I will not repair the wired controller because the cables have been detached from the board. Thats why i want to use the wireless controller now.
So, i wanted take out the analog sensor(joystick module) of the original wired controller and put it in the wireless controller to fix the high sensitivity.
Will it be really fixed ? Because its impossible to play with these high sensitivity.
And Sorry if my English is poor.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The problem is that the joystick module is worn out. Just replace the worn out one with a new one from ebay and that's it.
Do not take the joystick module from a working controller, why would you break a working one?
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Hello , I didn't fully understand your point. Because my english is poor. I wanted to says that i will use to joystick module of the original wired controller instead of buying new one and put it in the wireless controller to fix the high sensitivity. Will it be possible ? or if i do this the sensitivity will remain the same ? I'm very confused and want to make sure i don't do something wrong in this process.
door
You will almost certainly destroy the working module if you take it from the board, so just buy a new module an install it onto the board.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,335
