Ga door naar hoofdinhoud
Stripped, lower cost version of the XFX 680 chipset.
3 Vragen Bekijk alle
RAID 0 gone bad.
any ideas to get a raid 0 array working again? the drives are fine and all the data is on them, but raid doesn't want to recognize them. someone suggested rtools, but a demo version only lets you recover 64kb files. key? other options?
Is dit een goede vraag?
Score 1
1 Opmerking
did I mention this is for an XFX board?
read: running Windows 7.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If the RAID set is broken, yet you can read the data, your best option is to copy off what you can/need.
The only way I know to get a broken RAID 0 set back working is to set it up as new - which means the existing data is going to be erased.
RAID 0 is all about speed and performance - there is NO data redundancy... Depending on how your RAID controller and RAID 0 set was created, you may only lose files split across the drives (JBOD mode). If your RAID 0 was in Striped mode, you will probably need pay for something like rtools.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
that's what I figured, I'm trying to decide if rtools is worth it because I don't actually remember what's on them. If I knew, I'd be able to decide. Oh you, impasse!
door
R-Studio is a great thing. You will certainly be able to use it for other things beside this problem.
door
Voeg je antwoord toe
tabormeister zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 21
Altijd: 4,373
