Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Vragen Bekijk alle
Question about foam stickers and plastic cover on battery
Hi
I have a simple and maybe trivial question. I have been following this guide: MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement
When I start to assemble my macbook again, am I supposed to put the foam stickers in step 8 and the plastic cover in step 4 on again? And if they are not sticky anymore, what do I do then?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I wouldn't worry about the battery sticker. The foam gives some impact protection. I'd put the on and hit with just a little heat from a hot air gun or even a hair dryers, not to much.
Was dit antwoord nuttig?
Score 5
2 opmerkingen:
Thanks i'll do that.
door
By any chance you know where I can get replacements for the foam stickers?
door
Voeg je antwoord toe
Anthony Le zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 313
