Ga door naar hoofdinhoud
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Vragen Bekijk alle
What is the torque size to adjust the trackpad?
I installed a new trackpad but it is still not clicking. I want to adjust the torque screw on the bottom of the trackpad. I tried a T6 but it was too small. Is my screw ruined or do I need a bigger torque size?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It uses a T6 driver, check yours for burs or wear or twisted bit. Here's a video on doing it: https://www.youtube.com/watch?v=IuYO0I-D...
Was dit antwoord nuttig?
Score 4
Hi Theserj
This MacBook Model does use a T6 driver for the trackpad.
Do you have any other size torque drivers in your possession?
If your T6 was too small you may need a T7.
Are you able to provide pictures?
Score 2
Voeg je antwoord toe
theserj zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 266
