Ga door naar hoofdinhoud
Deze instantcamera van Fujifilm heeft nu een dunnere en lichtere behuizing dan eerdere revisies. De Mini 8 helpt de fotograaf door de aanbevolen diafragma-instelling aan te geven. Hij beschikt ook over een High-Key-flitsmodus waarmee de fotograaf zachte portretfoto's kan maken voor een verbluffend resultaat.
camera will turn on , red light at the back stays on.
camera turns on . but wont take a photo . red light at the backs stays on . and the light for brightness setting doesnt go on. tried to replace a set of batteries. didnt do anything.
Is dit een goede vraag?
Score 27
6 opmerkingen
Mine does the same thing except the brightness setting lights just all blink orange. And it will not take a picture. The film counter also will not reset with a new case of film?
door
My Polaroid just flat out will not turn on. It is brand new and i have tried to change the batteries. The red light will not turn on
door
just got my camera today I put the batteries in that came with the camera it only took 2 good photos then the rest turned out black I’ve tried everything nothings helped
door
Can you use batteries that have been recharged in your instax mini as well
door
I have put new alkaline batteries in, the right way. And my light on my camera is orange, It is not blinking. When I take photos they only show up white, even in a dark room. I am not covering the light sensor or anything. What is wrong?
door
1 commentaar meer tonen
Voeg een opmerking toe
13 Antwoorden
Het nuttigste antwoord
The red light is the Low Battery indicator.
  • When replacing batteries, use only new, fresh, premium quality alkaline batteries. Regular cheap flashlight batteries are not suitable.
  • Batteries have limited shelf life. Check that the batteries are not past their use-by date.
  • Beware of counterfeit batteries. These look just like premium quality batteries from well known brands but have inferior performance. They are often sold at convenience stores, sometimes at suspiciously low prices.
  • If you are positively sure the batteries are OK, and the camera still won't work, check the contacts in the battery compartment for corrosion. Clean if necessary.
  • If all else fails, have the camera checked. The camera may have developed a problem that causes excessive power consumption, thereby loading the batteries down.
Was dit antwoord nuttig?
Score 7
5 opmerkingen:
Where could I take my camera to get it checked? I am having the same problem, the red light is on but the settings lights does not. I also recently dropped it , but I hope it's not broken.
door
My camera just bounced off my bed and fell on my laptop. it looks like I'm my the only one who's experiencing this after it falling. The batteries seemed fine, what should I do?
door
Thanks! I actually dropped my poloroid a while ago and thought that was the problem but it turns out I hadn’t changed the batteries. Really helpful thank you!
door
What if my camera doesn't work and I just replaced the batterys with new ones and it's still not taking pictures? Can you please help me
door
Many people are having 3 red light issue it is a big issue but with many people and company service center is telling expense of 2500 rs
door
On my Instax 9 I take a picture and the red light turns on, then the camera makes a buzzing sound like it’s going to print the picture, then it doesn’t. The back where you load the film kind of pushes on the case and when I open it i hear some spring go back into shape or something?
Score 2
Me too!! It’s happened when my film stuck in the camera bcs the battery died suddenly. Have u solve ur problem?
Score 1
If you look inside of the battery chamber, it says to either use LR6 batteries, or 1.5 Volt batteries. I hope I helped
Score 1
Thanks for this answer! It turns out that i wasnt paying attention to the batteries i were grabbing from the container, and mustve grabbed dead ones when i was trying to replace them lol. That probably doesnt make sense, but if i hadnt looked up what the solid red light meant, i woulnt have replaced them. Thanks again
mine stays red but my batteries arent dead. i dropped them on the floor and they are fine. Maybe something else???
1 Opmerking:
Try 1.5 volt batteries or LR6 batteries
door
i have been doing that but still dont work
i have the same problems the red light on the back wont stop i cant take a pic bc it wont turn off and i changed batteries but it wont work either it still stays on my Polaroid is the mini9
1 Opmerking:
i have the same problems the red light on the back wont turn off it will only turn off if i push it back i tried changing the batteries it still wont work pls tell me how i could fix it
door
Make sure the bat your using is a quality brand with 1.5 volts.
I had the same problem. I was trying to use a rechargeable bat which had max voltage off 1.3v
I changed my batteries and it ended up being i had the plus and minus signs mixed up! I hope this helps. I was worried it broke! So glad it was just this.
I’m having the same problem and even have new 1.5 volt batteries in but it still doesn’t take pictures. Anyone know how to fix it?
Yes I have tried this but it still flashes red
Voeg je antwoord toe
emmanuelvillaroza zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 100
Afgelopen 30 dagen: 510
Altijd: 285,056
