Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
iPhone 5s black screen but its ON
my iphone 5s have black screen but its working in the background, and the wied think is that the phone is charging but when i connect it to a computer nothing is hapening ??? can anyone help me to solve the problem. thanks alot
Is dit een goede vraag?
Score 1
2 opmerkingen
What is the history of this phone? Waterdamage/cracked?
door
ist not waterdamage, but i think it was cracked screen, i replace few working displeys but still the same
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hey Vladan
What I suggest you try and do is connect it to your Apple AC Wall Plug Adapter and hold the Sleep/Wake and Home Buttons together until you see the Apple Logo (this is a hard reset).
This should only take a maximum of 15 seconds.
If this doesn't work then try checking the cables are connected correctly (Battery, Display Cables).
Regards
Brayden
Was dit antwoord nuttig?
2 opmerkingen:
thank for reply, but i do that already, i think its a hw isue but i cant find what is faulty, i am compatible with micro soldering
door
Have you checked to make sure that the display connectors are connected correctly?
Another thing I have found that causes this kind of issue is that the battery is not connected correctly, I suggest that you look at that.
Regards
Brayden.
door
Voeg je antwoord toe
Vladan Vojinovic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 1,822
