Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Vertical lines on display and ID toch not working :(
Hey guys.So I messed up my phone with upgrades.Few times I f**еd up battery,ear speakers,camera and flash light lol Then I was trying to install new housing I had issues with screws and I decide to use clue to take them off,any way,this time when I took phone apart everything went well except the one thing that screw did not came out I put it back together and then Touch ID stops working and I got vertical lines on the screen.Im just so upset on my self and it's expensive thing! Anyone can help me to find solution,maybe replace flex cable,or should I replace the screen?
Half of the screen not working as well and I can't unlock my phone :/
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Check the digitizer connection to see if it's slightly bowed (the upper of the four screen connectors) . Even a tiny bow can cause those symptoms.
Was dit antwoord nuttig?
3 opmerkingen:
I did check it so many times! Really I don't know what to do.Just probably will get another phone :/ I took the metal shield from the back and there was flex cable from Toch ID and it even got worst :/ I clean so many times flex cable connection it's not helping way.Maybe I just should replace the sheild?
door
I would try a known good screen, make sure that works.
door
To get new screen gonna cost me helf of the price of the phone.I just decide to get new phone.But I may gonna get shield and will try to replace it.So as I can see there is very high risk to damage the phone if u need to replace Toch ID flex cable,because it's not like on IPhone 6,it's inside the shield :/ I need to replace Toch ID flex cable as well :/
door
Voeg je antwoord toe
Daniiel Tsykhorskyi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 634
