Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 it's not turned on and charging
i own iPhone 6 yesterday it's run out of charge and i left it for today without charging when i wake up i try to charge it but it do not charge and do not turn on iOS:9.3.1
please help me...
thanks a lot
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would first try letting it charge for about 10 minutes. If the phone is completely dead, it may take a little time to give it enough juice to start up.
However, I'm assuming you've already tried that, and it seems like too easy a solution, so next is to try doing a soft reset. Do this by holding the home + power button at the same time for about 15 seconds. If you are lucky, then the Apple logo will appear and once it boots up fully, hopefully it will charge as well. That is the simplest solution without having to get your hands dirty.
If neither of those steps work, then you may have to open up the iPhone. If you do not feel comfortable doing this, bring it into a local cellular repair shop or sell your device on eBay, Craigslist, etc. or if it's a relatively new purchase, bring it to Apple. They can at least tell you what may possibly be the problem, and point you in the right direction.
But if you do open up the iPhone, check the battery, lightning flex cable. Hopefully it will be one of those two that have gone bad, otherwise you're looking at repairs on the motherboard, which may not even be worth the hassle.
Best of luck!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Appreciate your help and your detailed answer, i already did this steps as a sequence and no hope, it's the motherboard i don't know what happend and what the cause of this.
thanks for your help
Ramy
door
Voeg je antwoord toe
Ramy Torky zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 76
