Ga door naar hoofdinhoud
The Kodak ESP 3 is an all-in-one photo color inkjet printer.
Printer won't "startup" when powered on
When I press the On button my printer begins to start but then stays in "Startup" mode and won't continue to boot up. To turn it off I have to unplug the power cord because none of the buttons on the control panel will work.
Is dit een goede vraag?
1 Opmerking
My printer is a Kodak ESP C310
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
What is the exact model number of your printer, is it 3, 3.2 or 3.2s?
You may be able to fix your problem by reloading the firmware but because the firmware is different for the 3 models you need to install the correct one otherwise it may render your printer inoperable.
Here is the link for a Kodak ESP 3 printer firmware download, Windows OS.
http://support.en.kodak.com/app/answers/...
Here is the link for a Kodak ESP 3.2 printer firmware download, Windows OS.
Here is the link for a Kodak ESP 3.2s printer firmware download, Windows OS.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Randy Cantor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 2,225
