Ga door naar hoofdinhoud
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Vragen Bekijk alle
Ifixit says I need 10600 RAM but OWC says I need 12800.
So I bought this RAM a while ago for my 2.4GHz MacBook Pro Late 2011 which is PC 10600 and everything seems to be working fine. ifixit says I have the right RAM for my computer but OWC says I need PC 12800. Can anyone confirm what would be best for my computer?
Is dit een goede vraag?
Score -1
1 Opmerking
Here is the EveryMac spec listing of your system: MacBook Pro 13" 2.4 GHz i5" (Late 2011)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
As you can see EveryMac lists PC 10600 1333 MHz DDR 3 SDRAM for your system.
While you can use faster speed modules they do need to be the correct type.
The only difference between DDR3 and DDR3L is the L modules run at a lower voltage so they run cooler and give you a bit longer battery life when your on the run. Both will work in your system.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Erik Ashlie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 146
