Ga door naar hoofdinhoud
Microsoft's derde generatie Xbox game console, uitgegeven op 22 November 2013.
727 Vragen Bekijk alle
Why Am I Still Having Wi-Fi Issues?
Okay, so, I've tried everything. In no specific order, I've factory reset the console, I've done a hard shutdown, I've changed WiFi names and passwords, used no password, etc. It's not that the Xbox won't connect, it doesn't even find the network! And if I try 'Test Network Connection' it gives me an error and says my hardware is messed up and I have to send it in. So I went out and bought a WiFi Card for the Xbox and replaced it myself (super easy, the case pops off and there's 2 screws holding the chip). I powered it up and BAM it works. I play a bit, watch some YouTube and then I went to bed. I get up this morning ready to play and it's doing the EXACT. SAME. THING. What could it be? The only thing I can possibly think of is my Internet source which is a mobile hotspot. But it worked last night, so I have no idea.
Is dit een goede vraag?
Score 1
1 Opmerking:
Are you using the "new Xbox experience"? I had a similar problem... It was a driver problem that was fixed...
door
Voeg een opmerking toe
1 Antwoord
When the XBOX can't your hotspot, have you checked to see if any other devices can see it?
Was dit antwoord nuttig?
Voeg je antwoord toe
Jared Horne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 111
