Ga door naar hoofdinhoud
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56 Vragen Bekijk alle
Nokia Lumia 920 not turning on
i also have the same problem and always do the same thing by press the volume and power on/off and its works usually. but now its not really work. there are no any response when the phones was charging. it looks died. the hard reset also cannot do anything. whats the problem??!!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Connect the phone to a PC (be sure your cable is working).
Try to switch it on. If the PC recognizing your device 90% you have a SW problem. Try to restore the phone:
Windows 8/8.1 Windows 10 Boot Manager Error Solution
If your PC does not respond when you connect the device, then the problem is hardware, broken USB connector, logic board damage...
Regards.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
@zfix I referenced one of your you tube videos to help someone just now thanks for the video it was great
door
You try reset factory?
Voeg je antwoord toe
caercspf zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 498
