Ga door naar hoofdinhoud
Samsung Galaxy Star Pro Model Number S7262. Released in 2013 of October
7 Vragen Bekijk alle
Why is my headphone not working?
The audio on the headphones fail to work completely. The audio may be cutting in and out, only working on one side of the headphones.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
There might be dirt build up or water damage in the audio jack, but try a new pair of headphones to see if the headphones are the problem. If they are not the problem because they work fine for your other devices then replace the audio jack in your device.
Was dit antwoord nuttig?
Score 1
may be a lot usage of ur headphone may damage the fibres of your headphone and also may be the magnet used is wrecked or maybe the soldering used to attach your headphone speaker and the pin may be damaged due to over use.
Voeg je antwoord toe
Kevin Teque zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 486
