Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
Is it possible to test a mic with a multimeter?
I need to test several mics for the iPhone 1st Generation. Sometimes they come damaged, and the only way to test them is soldering them to the System Connector. Is there any way to test a mic with a multimeter?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you want, you can cut the end off of a 3.5mm audio cable, and attatch the 2 wires to the mic, and plug that into the microphone/audio-in jack of a computer and see if you can hear anything.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I will try and let you know...thank you!
door
Voeg je antwoord toe
Flavio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 3,358
