Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor Sanyo digitale camera's.
69 Vragen Bekijk alle
Card Error---- only works with internal memory.
I have a Sanyo VPC-E2100. When I attempt to use an SD card, the viewer screen is blurred and says "card error". This is a new SD card and works fine in other devices.
The camera works fine however, without the card and will take pics and store to internal memory. Help!
Is dit een goede vraag?
Score 1
1 Opmerking:
Hi Angela,
Have you tried formatting your SD card? Keep in mind that formatting a card will erase all data, so make sure to transfer your images (if any) to your computer first.
door
Voeg een opmerking toe
2 Antwoorden
First off look at the card. I have this camera and it is a really good camera. You can use a class 10 sd card in it. I use a class 10 sd mini with an adapter. What you want to look for is a small "10" on them. You can also use a lexus 8Gb down to a 2MB. The max is a 32Gb I use one that comes from sandisk, just make sure it is class 10.
Was dit antwoord nuttig?
I have a sanyo vpc-T1060 camera. I bought a new san disk, 1 gb and when i put it in the camera i get a messageprotected card. What does that mean and how do i fix it. I put the old s card in and that works find. hope you can help bill russell43us@yahoo.com
Voeg je antwoord toe
Angela Beck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 29
Altijd: 537
