Why does my coffee overflow the filter basket?
When I brew a normal pot of coffee, the filter basket overflows with coffee and spills all over the place. What am I doing to cause this to happen?
Is dit een goede vraag?
After working through all the usual suspects (coffee grind, filter condition/type, bean variety, the drain hole/trigger in the filter basket, etc.), I converged on this solution. The interior surface of the filter basket has deep ridges on which the filter rests. These ridges create conduits to promote water flow, but coffee oils can cake inside these ridges and prevent water flow. Unfortunately, a standard coffee machine cleaning does nothing to remove these oils. Either elbow grease and a scrub brush or the dishwasher is all that will clean the basket ridges. The basket being black doesn’t help identify the problem, but I noticed when the ridges are clean and free of oil and residue, the ridge surfaces are no longer dull in appearance, rather, they appear glossy.
Was dit antwoord nuttig?
Your problem could be from using too much coffee grounds, a bad filter and/or too many filters. If you use too much coffee grounds the coffee maker will not brew completely causing it to over flow. If you use a bad filter like a cheap brand filter this will cause an overflow. If you use too many filters the coffee ground won't brew almost anything causing it to overflow as well.
not using too much coffee for water used. maybe you could give me deeper filters, been unable to find any.
I believe American coffee makers are made for weaker coffee. No way I can add a scoop per cup no matter how ground. I ended up going back to French press and using coffeemaker only when I have a lot of company. Then I turn it off mid way through so the water level can go down in the basket. Then I turn it back on. A pain but only once in a while when I have house guests.
I believe American coffeemakers are made for weak coffee. No way I can add a scoop per cup of coffee. I've gone to using French press and only use coffeemaker when I have a lot of company. Then I turn coffeemaker off mid way to allow basket to drain and then turn it back on to finish brewing.
I have owned a Hamilton Beach Drip Coffee Maker for over a year now, use it every day and never had a problem until recently. Every time I use it I have coffee grounds everywhere. Evidently the basket is overflowing during the brew.
I clean the basket and make sure the hole is not clogged after every use. The only thing I can figure is that the water is shooting out too fast into the grinds or the spring loaded basket is not working. I have tried to take off the water dispenser to clean it but can’t figure out how to get it off.
Any suggestions?
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 58
Afgelopen 30 dagen: 278
Altijd: 6,942
