Stopped before compleing last cycle
Why the washing machine doesn't complete it normal wash cycle at the rinse step?
Is dit een goede vraag?
Water Inlet Valve
During the rinse cycle, the water inlet valve opens to allow water to enter the wash tub. If the water inlet valve fails, the washer will continue waiting for the water to enter the washer, causing it to stop mid-cycle. To determine if the water inlet valve is defective, use a multimeter to test it for continuity. If the water inlet valve does not have continuity, replace it.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 213
3 opmerkingen
A service man has diagnose the electronic timer. I changed for a new timer and calibrated it. The problem stills.
door Trahan
I Mayer. When the washing cycle stops, the light "rinse" steel on and the door unlocked. To continue, I have to push 2 times the button start to lock the door. Rinse start and complete. Do you think that the water inlet valve still affected the problem?
door Trahan
The water inlet valve is ok. Test continuity is ok. Problem still there. Is it related with the push button start???? After changed timer at 400$ CAN. and proceed at many washing tests, I am ready to give up. Desesperated Alou.
door Trahan
