Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Samsung WB35F-camera, geproduceerd door Samsung in 2014. Samsung WB35F 16,2 MP Smart wifi- & NFC-digitale camera met 12x optische zoom en 2,7"-lcd
Why won't my camera turn on?
My camera is fully charged and it still won't turn on. The screen will stay completely black; no low-battery or anything showing. I've tried charging it then turning it on while it's charging but that doesn't quite work either. What do I do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Too much anime?
I'm kidding...I think?
Has your camera ever functioned with out a battery and just the power supply?
I'm not an expert even with my own personal endeavors, BUT; I do know that batteries are a commodity. Rechargeable batteries are not an exception. Their just not replaced as often...but even that seems to becoming less accurate.
Try a battery tester, not a voltage tester or multi-meter but a battery tester.
Correction: the above will work if, there is a proper load across it at the time of measuring the potential voltage difference at the positive and negative leads/ends/points.
A battery could show a full charge, voltage wise, but not have the available current needed to drive your device. In this case, your camera.
Digital cameras eat current and poop pictures
Some multi-meters do have a "battery test" selection/option. There is a small load inserted so that it gives a accurate, (more accurate) indication of the health of the battery.
(The correct terminology is cell...a battery is made from two or more cells. Thus there is NO-SUCH thing as a AA or AAA or AAAA or C or D battery. There is a 3, 3.6-3.7 volt battery , a 6, 7.2, 9.6 volt battery and of course a 12, 14.4, 18 and 24 volt battery. [and higher] All of which are made from multiple cells. )
This may or may not be the issue to your camera. But knowing this will help in the future when troubleshooting devices that use a battery...or multiple cells...but why it still doesn't power with the power supply attached could be, possibly, just....maybe because of the battery's poor health.
Now, from my archive of repairs, in the digital camera folder is a Nikon L100. (piece of crap to many including myself...belonged to my father) It would not power on any more. It used, still uses, 4 AA's alkaline batter-OOPS...cells.
My father purchased a Super Charger back in the 1980's. No not a car. The first alkaline battery/cell charger. Made specifically for alkaline, although it had a option switch for Ni-Cads.
Sold for about $60.00.
I still have it and it still functions.
Now, alkaline cells were not designed, probably not, to be recharged although they could be if maintained and executed in the correct and recommended fashion. This was to keep the cells always charged.
Hmm?
In other words, don't wait until you notice your flashlight is getting dim.
Recharge them after EVERY use and don't run them down to the point that you notice that they are not performing well.
They may charge up again after draining them heftily but not to the point you would like or expect.
Often in these situations the Super Charger would indicate, "Charged" and when placed back into the device, a flashlight with a filament type light bulb, the bulb initially starts bright and then quickly dims down.
This is why a proper technique for testing is required. 1.5-1.7 volts reading on a voltage tester could yield a situation as above.
So, the alkaline cells that are subjected a not so perfect regiment of use and recharge often would start to become visually bad. They would start to leak. If a cell was not identified as becoming bad, it would often be placed back into the Super Charger. Subjecting it to more strain and now leaking into the Super Charger.
Sometimes though, as the case of the L100, the cells were reinserted into the camera and remained there for a period of too long. TOO too long. Until the family reunion, which was approaching and my Sony lens cover finally gave out due to a broken tooth on the gear that engaged the array of ....anyways, The Nikon was going to have to be the alternative and when testing, it would not energize.
Inspecting the batteries I noticed some acid corrosion but not from them, from within the camera.
Looking deep down the battery compartment, (that is what Sony officially labels it as) I can see MASS corrosion. My first conclusion: Dad! You put bad batteries into your Nikon!
I have disassembled many, many, a lot of things for the purpose of repair and many if not most were successfully re-assembled and often worked. Maybe not on the first round.
I would rather tear down a laptop completely than disassemble a camera with the intention of reassembly and having it work. Luckily my Sony still functioned. I used it to take pictures through the stages of breakdown. The only way to clean that corrosion was dismantlement...completely.
To my amazement the corrosion was not the result of bad batteries. It was the result of a bad flash capacitor...and what a mess!
I searched for a replacement inside every camera Goodwill had for sale that weekend. ( I just kept exchanging them for the next) No such luck. BUT, it just so happened that my Sony had a really close match. So close it actually fit and I was able to get the camera back together and it still functions, (8 years later), today.
Something to check....For your sake, I'm not sure if it would be a good thing or not should it be a bad flash capacitor.
Good luck!
...modifyman
Was dit antwoord nuttig?
Score 2
1 Opmerking:
i love you
you're really sick
so to say this i've even signed in to this random site
and texting it with my broken English
also my camera (samsung st66) still can't start
more exactly the when i'm tapping to the power button the green indicator turning on to the moment and again shut down
and even screen can't light also objective don't even move
by the way me too tear down technique to fix
door
Voeg je antwoord toe
Anime Lover zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 3,967
