Ga door naar hoofdinhoud
2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Vragen Bekijk alle
Vraag afgerond
Compatibility of Logicboards A1211 in a A1226
Hi,
I would like to fix a MPB A1226 (broken logicboard) with parts of a A1211. The A1211 has a very damaged body and a dark screen (inventor).
Can I use the logicboard of the A1211 for the A1226?
In general, the A1226 is in a pretty good shape
Fans, super-drive and some cables of the A12226 have been replaced. HD, battery and RAM are quite new.
So, I would like to fix the A1226.
Yes, I checked the threads and searched google for information.
Thanks
Q-Wing
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
No they have way to many parts with most with different motherboard connections.
A1226,A1260 LED display versions both compatible 2.2, 2.4, 2.5 and 2.6 processors all will swap between each other.
The A1211 A1150 compatible to each other - they use the LCD display.
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 201
