Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
apple logo flash then black, backlit screen
Ok so, itried fixing a water damaged iphone 5s today and did the whole alcohol thing. so i put the motherboard in and tried turning it on... nothing. so i plug it in then i get an apple logo for about half a second then it switches to a black backlit screen and stays there. maybe i didnt remove all the corosion and need to clean it more? by the way i did plug it and itunes recognizes it and i restore it... i get an error code 3194. right now i am stuck and have no clue what to do because i spent a lot of money for the parts. I know the parts are 100% working because i tested them on a different motherboard. also lastly my phone doesnt turn on unless its plugged in.
Is dit een goede vraag?
Score 2
1 Opmerking
I have the same problem, tried the solution and it doesn't work, what next?
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
DFU Mode
1. Plug your device into your computer.
2. Turn off the device.
3. Hold the Power button for 3 seconds.
4. Hold the Home button without releasing the Power button for 10 seconds.
5. Release the Power Button but keep holding the Home button.
6. Keep holding the Home button until you are alerted by iTunes saying that it has detected a device in Recovery Mode
Make sure the device screen is blank and no logos are present.
Restore the phone :)
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
i have plug my device into the computer but unable to turn off the device... keep on and off showing apple logo and black screen
door
it does not allow me to do this it just flah back very quickly
door
i tried that but when i am plugging the lightning cable on my device it flashes apple logo then leaves backlight on. the itunes also automatically detects the phone on recovery mode please help
I'm having the same problem. Can't find any information that's actually useful. I did find out though that the iPhone has been opened before given that it had a sticker inside it which read 'happytel' I'm guessing this one may have been repaired for water damage. It's difficult to find solutions for these things. I'm going to try exchanging parts with another iPhone I have but don't have much hope.
I had this problem a while back your battery is bad
1 Opmerking:
did you change it and does it works
door
Voeg je antwoord toe
christian lopez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 35
Altijd: 23,679
