Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone doesn't charge after drop down
Hello everyone!
I dropped down my iPhone 6. The phone had only cracked screen, so I was happy with result because the phone still worked. But! Before I came home, the phone was out of battery, so I plugged it in to the charge but nothing happened after 24 hours in charge. DEAD.
I tried to change battery but still nothing.
When I tried to measure the battery after 24 hours in charge, it had 0V.
I tried to measure input voltage on motherboard and it had only 0.8V and I think that is a problem.
It looks like bad charging dock or something like that. What do you think?
Thank you!
Is dit een goede vraag?
Score 1
1 Opmerking
Thank you guys. I hope that will be the right solution.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Definitely the charging port.
Was dit antwoord nuttig?
Score 2
If the lightning cable doesn't go in fully into the charging port then you'll need to clear it of debris inside the charging port. Something like a toothpick or equivalent will work for cleaning it out.
Score 2
1 Opmerking:
I think that the problem will be inside charging port. I will buy new one.
door
Voeg je antwoord toe
Milan Rada zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 149
