Ga door naar hoofdinhoud
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Vragen Bekijk alle
Cpu upgrade options for mac pro 5,1
I am considering buying a used mac pro 5,1. However, I want to know what chipset the mac pro has before I buy. The only place I could find the chipset listed was on Wikipedia and it was wrong because according to intel, that chipset(X58) supports few to none of the listed cpus the mac pro can come with from the factory. I was wondering if anybody who has a mac pro 4,1 or 5,1 could tell me what chipset it has so I can check on intel's site to see ALL of the possible cpus the mac pro 5,1 could have.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
If you purchase Mac Pro 2010 or 2012 with two processors (2x6=12 cores), I suggest you to upgrade its CPU into Intel Xeon X5690 (3.46GHz),. Till I write down this today, the price of X5690 on ebay is around 400$ for a pair (two) of CPU alone or, around 600$ for a pair of CPU plus kits. This price is not included the service. You can find "how to" instructions on YouTube or other place.
You can buy the lowest Mac Pro with 2.4GHz (around 1000-1500 now ) then upgrade its CPU by your self. Don't forget to upgrade its RAM too!
But, be careful to choose the right one since many (!) Mac Pro 5.1 is actually the upgraded Mac Pro 2009 (4.1).
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
So a tray from a 4,1 wont work on actual 5,1 machine?
door
No it won’t. The trays are not interchangeable
door
The 4.1 and 5.1 are identical, It does not matther if you utilize a 2009 4.1 or 2010 5.1 Mac Pro...
The only differance is if you want the same upgrade options on the 4.1 as the 5.1, you just need do upgrade your firmware.
It does not affect if you buy a flashed 4.1 to 5.1 as the electronics and the complete logicboard is 100% identicle.
(Yes, Apple did rip off its customers by releasing the 5.1 as a new model...)
door
Review this sites info: EveryMac - Mac Pro's. Locate your exact system and post an update to your question with the info as there are a few different models and not all of them can be upgraded.
Update (03/23/2016)
The MacPro5,1 uses two 6 core Xeon CPU's: X5670 (12M Cache, 2.93 GHz or X5675 (12M Cache, 3.06 GHz.
But without knowing which logic board you currently have as you didn't tell us. I can't tell you if these CPUs will work or not as the socket and the firmware within your system will dictate if these CPU's will work.
Score 2
6 opmerkingen:
http://www.everymac.com/ultimate-mac-loo...
Any of the eight or twelve core systems on this page will do
door
They all have the same chipset (which one is unknown to me), and the socket FC1366. I do not have a Mac Pro, as I stated in my question I am considering buying one.
door
Often one would have more details on a system they are planning on buying (i.e. seen it or could ask for more details from the seller).
door
If you do a major change make sure you have the original system installation disk as it has the fan syncing software on it and you will need to run it. If you do not you will have run away fan problems.
door
I do not have a specific seller in mind, I just want to know a little more about the machine in general before I find one I want.
door
1 commentaar meer tonen
Check out the upgraded processors boards the seller is offering. They are some of the fastest Macs ever!
http://stores.ebay.com/brgins4sale?_trks...
Score 2
I recommend sticking with the Westmere processors on the Mac Pro 5,1. The 6 core is the best value Mac Pro you can purchase. My two cents...
Score 1
Mac Pro 5.1 cpu is on the x58 platform
LGA1366/Sockel B
https://www.ebay.co.uk/itm/305467618503?...
Voeg je antwoord toe
Jackson Tint zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 68
Altijd: 36,194
