Screen tearing, stripes, flicker, distorted proportions
Hey, I get all the symptoms listed in the title shortly after I open the lid. On an external display everything is fine.
I took the machine to a free check at a certified repair shop and they told I need an 627€ maintenance, where they'd change the display. Otherwise everything seems fine. Most strikingly the laptop is perfect for 5-10 seconds when opening the lid after a pause in use.
Im trying to evaluate my options:
1. Is the display really faulty (since it works for a short while) and could I fix simply by reconnecting the wires
2. Is the display the only faulty part and I could simply fix it with a new unit for 350€+posts
3. Is there something really wrong with my laptop and money spent on repairs will end up wasted
I would greatly appreciate if you can explain what might be causing these symptoms and what could be the most cost effective way to proceed.
http://i.imgur.com/toxSFmi.jpg
Here's an image to clarify the problem with my screen, and again on external display everything is fine. Thank you in advance for helpful messages
Is dit een goede vraag?
@erickk hi
can you play with the display whist on to see if it makes any difference ( move back and forth
also how is you hinge
door Alex Hus
