Ga door naar hoofdinhoud
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
No Mobile Data Connection
on a network compatible with my factory unlocked gsm device, apn setting are correct, no sim card errors, phone recognizes the network, but even when i do have service bars i cant call, it doesnt ring or dial out it just hangs up saying mobile network unavailable, cant send/receive texts, and cant get in the internet without wifi. my IMEI is not blocked and the software repair with sony xperia care didnt work on resolving the issue
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Are you running currently with 4G enabled? When you do calls it switches to 3G in order to connect the call.
Anyway inside the phone there is an antenna cable which can get disconnected if you've dropped the phone, also the antenna cover will probably need to be realigned by unscrewing the to screws at the bottom of the phone. You'll need to push the antenna cover down so that it has full contact with the antenna pins before you screw it back in.
Check out the z3 ifixit guide to remove the back cover.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Cliffton Thyarion zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 3,938
