Charger Not Recognized, Battery with Yellow Triangle and Exclamation
My wife's Galaxy S5 G900A stopped charging last night. This morning she plugged it in to a different, known good OEM charger and it didn't recognize the charger, stayed at 2% all day. When I got home from work I turned it off and it shows a gray battery and then a yellow triangle with exclamation point. I swapped the battery with one from my phone (exact same phone) and it is behaving the same, but the battery percentage shows 64% which is what my phone showed. I put her battery into my phone and it showed it was 99% charged. I then put the batteries back into their respective phones and now then her phone showed its battery at 99%. I tried cleaning the charge port with alcohol and a toothbrush, then blown out with compressed air, but no change. I tried looking for tests in the diagnostics menu, but didn't see anything related to battery or charging.
The only thing left to try is to reset the phone. It is already on 5.1.1, which is the latest update available. Any other ideas that might fix this problem? If the reset doesn't fix it then I will try a replacement charge port board.
Is dit een goede vraag?
12 opmerkingen
Cool, that's what I figured, was hoping someone could confirm since I didn't want to go through backing up and restoring everything.
door Joe
Yes, you can try that but If you have tried your two options and somehow, it dosnt solve. Visit us at https://cellxperts.net we offer our best cell phone repair Cary NC.
door SEO Mobilephone
my sister had the same problem with her mobile , downloaded power sharing app , and it worked , i guess the problem is in the software , so if anyone could try to update or reset there mobile and see if that would work too or not .
door sandrew raafat
Just an idea, try turning it off and removing the sd card and sim card and then try charging, worked for me!
door Albino Rhino
getting cross yellow triangle wtto do to slove this problem
door thammishetty lokeshwari
7 commentaren meer tonen
