Ga door naar hoofdinhoud
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Vragen Bekijk alle
Why should my ac adapter get so hot?
I replaced my ac adapter about 6 months ago and it's getting very hot. Why?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It's shorting out. You need to replace it. Did you get an off brand? If you tell us which machine you have we can direct you to the correct replacement. Go to this link to help identify your Mac: http://www.ifixit.com/Mac-Parts
Was dit antwoord nuttig?
Score 2
1 Opmerking:
+ Please replace sooner rather than later--if it shorts completely it could cause a fire.
door
The more the laptop gets used, the warmer the adapter may become.A relatively warm power adapter is normal, especially when the laptopis being used and the battery is being charged
Voeg je antwoord toe
rsmsem2 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,613
