The Power button does not appear to be damaged. I've tried plugging the printer in in another room (by itself, no computer) and still nothing. I've also left it unplugged overnight and even tried using a different power cord. It just will not power on. Note, the printer was working just fine yesterday afternoon. The only thing I did was turn it off in mid-operation.
Even if the power button were damaged (and I see no sign that it is), it should turn on by itself when I go to print. Instead, I get an error message simply saying "the printer is not ready." (at first, I was getting a message that "the printer is offline", but I was able to toggle that by going into the Printer Properties in Windows and changing its online status.)
The printer is only slightly over a year old, so it's no longer under warranty (naturally). Newer models are junk, so even though Canon has a "trade-in" program, I'd rather fix this one (which SHOULD be something simple).
I bought the "Canadian" version of this discontinued printer specifically for it's CD printing capabilities. Newer models... and ALL U.S. printers... disable this feature (by law?) According to Canon (after I asked), there is no fuse inside the unit that might have blown.
12 opmerkingen
Seems to be a fairly common issue where these printers are becoming paperweights...It would be nice to get printing again! Has anyone found an actual solution to this problem?
door Paul
I have the same printer and it turns on, but nothing beyond that and it can only be turned off by unplugging (as with the OP). There are a few things that might revive it like making sure the fuser temperature safety hasn't been thrown (do an Internet search on this; I did that but it didn't help me). Your printer like mine clearly has a circuit board failure. If you are willing and able to tear apart the printer and do the work yourself you can find (again through searches) replacements for the two main boards in the printer, and they would not be difficult to replace once you figure out the magic of taking the printer apart. However, you're probably looking at 100 to maybe 150 (or more) dollars for the two circuit boards and so you have to decide whether it makes sense to repair it. If you would have to have a repair shop do the work I'm certain you'd be wiser to take the printer to the electronics recycler and dispose of it. I am not delighted by that prospect but I may do that and be done with it.
door D. Spencer
You can fix this by going into the Easy Print Manager SyncThru Web Service. Here is a link with instructions: https://www.amazon.com/review/R3IY5Z5BEN...
door Greg M
Why is it so hard for people to understand the issue here? The problem I have had with my Samsung C410W (and from Internet searches I've done many others have had the identical problem) is that you press the power switch, the blue light around it comes on, and that's it. There is no sound, and you can only get the thing to turn off by unplugging it. Plugging it back in does NOT "wake" the machine up, it does nothing. The RJ45 (network) port is dead, the USB port is dead. If you connect the printer to your computer with a USB cable, operating system of your choice, the printer is invisible to the computer. You can't resolve this printer problem with software running on a computer that does not see the printer, obviously.
I replaced the large board on the printer left side, no effect. I replaced the small board on the back right (with the USB and RJ-45 ports) and that fixed it. The board, JC92-02483A, is the central control board with the ARM chip. Samsung sold its printer division to HP a year or more ago.
door D. Spencer
I have exactly the same annoying issue. spent a lot of money for toner and even sent it back for repair. They said it's working. When the printer setteled for a few DAYS it might come back once or twice - then going to deep sleep again. SyncThru does not recognize it and even through USB it's invisible for the computer. This really sucks. And why doesn't any technician or official at Samsung (HP as it seems to be ...) admit that their is a BIG problem! Anything I can say: keep your fingers off these machines!
door Ro_Ri
7 commentaren meer tonen
