No sound on tv... Any way to fix it?
Tv has no sound! Changed cables but still no luck!! Been working fine one morning and couple hours later sound just stopped
Is dit een goede vraag?
Hope this helps Calvin Mogilinski
Here are the most common reasons you may not have sound.
Starting with the most common solutions for no sound from TV:
Television Has No Sound Answer 1: Make sure TV is not muted.
Television Has No Sound Answer 2: Make sure the TV is not set to SAP (secondary audio protocol)
Television Has No Sound Answer 3: Make sure TV input is correct (someone may have accidentally pressed the “aux” input button or similar causing the TV to use an input with no sound going to it)
Television Has No Sound Answer 4: Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.
Television Has No Sound Answer 5: Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)
Television Has No Sound Answer 6: If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.
Television Has No Sound Answer 7: Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.
Television Has No Sound Answer 8: If using an “S” video cable into an input on the back of your TV, these cables carry no sound, just video, so make sure you connect an audio cable too.
Television Has No Sound Answer 9: Hook up an external device to the “TV audio out” input. This will be the test to see if it is a TV circuit board malfunction or the speakers are faulty in your TV.
Television Has No Sound Answer 10: If you are connected to a satellite box, use the included remote and go into the “menu”. Check to make sure sound settings are set correctly.
Was dit antwoord nuttig?
The audio on my Vizio television goes out when CNN goes from commercials back to regular programming, or switching from premium cable channels to local channels. In order to receive audio, I have to turn the tv off, then on again.
The audio on my vizio tv 42inch has no sound I replaced IR board but still no audio.
my supersonic model slm - 3203 is not working properly when you switch on tv picture comes on and after 5 seconds turns black but the sound is working perfect. please help how to fix this problem?
When I switch on my Skullcandy bluetooth headphones the tv sound output changes to headphones, but when I switch off the headphones the tv sound doesn't come back on. Why not ?
Television Has No Sound Answer 7: Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem. JUST UNPLUGGED EVERYTHING!!! RESTARTED CABLE BOX VIOLA!!!!!!! AUDIO THANKS SAVED ME FROM BUYING A NEW TV TODAY!!
I had the same problem.....turned out it was the scart leads needing pushed into the back of the tv and or the tv box
Fixed the no sound on my vizio by replacing hdmi cable. Simple and effective. Also pic quality much better.
Hello. Thank you for your answers. It has helped me. I had no sound. I tried everything listed til I tried changing out my HDMI Cable I have sound. I also changed placement to back HDMI from the side plug in.
Everytime I turn off my Visio off and on again, I have no volume.
My TV speakers inside, always turn irself off.
I have to reset EVERTIME I turn my TV on!!! HELP.
Supppose its not all the above but ic problem
This happened to me also. Sound just quit while watching a show on vizio d series smart tv. I had to do a factory reset and sound was back.
Fix my sounds for everything
I have one local channel that has no sound. Been out about one week.
The audio on my Vizio E48-DO television was going out when CNN goes to commercials or any other channel. All of a sudden audio goes out but picture stays. Spectrum went digital and they gave me a box to see digital channels. Problem stats right after that. I got it straightened as follows. First download app of vizio smartcast in your cell phone and pair the tv with it. find out the remote functions in it. Go to settings. Go to audio. Make sure it is on beatstream . Another thing make sure you put speakers on ON. once this is done it works like a new tv. Hope this help someone.
I turned off the audio leveling feature and like magic my sound started to work again.
VIZIO with WALLY (Dish network) hooked up via HDMI would lose sound, when sometimes changing channels. The sound emblem on the TV showed as it being turned up. (however, No Sound) If you tinkered with it, you could eventually get it to work, but it would quickly happen again. The funny thing is, it worked fine for over a year, nothing changed or adjusted, then just started doing that. WEIRD Anyway, I discovered this:
SOLUTION: Wally, (satellite receiver box) or other Dish satellite box, hooked up HDMI, Go into settings for AUDIO OUTPUT, Turn off, Dolby Audio, and Volume Leveling, Reboot Box, and TV
This solved the Sound Problem, I imagine this would work similar with other boxes hooked to your TV. Hope this helps?
I have a story and it will shock you how simple the fix was.
I put my 50” tv to the curbside with a taped baggie that held the remote. Made a big sign and taped “Works but no sound”
About a week later, the guy that picked up the tv said hey thanks for the tv!! He said it was dusty and had pet hair in the sound vents!!
Try using a shop vac and suck all the dust and pet hair out.
Afgelopen 24 uren: 55
Afgelopen 7 dagen: 334
Afgelopen 30 dagen: 1,664
Altijd: 325,674
11 opmerkingen
if nothing else works, use a sound bar or sound system, and connect the sound cables to the system instead of the tv. I did that and it works.
door rmsstudentgov
I have a 32 inch sceptre tv. The sound comes and goes. What is this tv problem. Help
door Jan
That worked for me too... then it dawned on me, the audio is coming from the cable box not the TV... duh, thanks for the help!
door johnlaury
I just had this problem what worked for me is power cycling the tv which is unplugging the television cord from the back of TV then pressing the power button on the tv for 5 seconds I actually did 10 sec then afterwards plugging and turning tv back on Viola sounds was working again whew I’m happy I had this tv almost 13 yrs
door fadil Younglao
Fadil Younglao, this also worked for me. I could not unplug the cord from the Panasonic tv. It is not a smart tv. I unplugged it from the wall, plugged it back in and held the power button for about 5+ seconds. The sound worked again when I turned the tv back on. The kids use this tv and a neighbor gave it to us used in 2009. So, we have had this tv for 11 years. I don't know when he purchased it.
door Jocea
6 commentaren meer tonen
