Ga door naar hoofdinhoud
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 Vragen Bekijk alle
Vraag afgerond
Display Flex Cable Connectors
I make the procedure to clean up my display with clouding. In the disassembly i make a mistake and break the logical board connector and the flex cable, i know that's replacement for the flex cable but can i repair the logical board connector?
best regards
Alfonso
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hello, Alfonso -
It depends on two things:
1) If the connector pulled off of the board cleanly, without structural or mechanical damage.
2) if you have the skills to do surface-mount soldering, or know somebody who does. Probably needs a microscope, very steady hands, paste solder, and a hot-air soldering station.
It is a very challenging repair. Good luck!
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 91
