Ga door naar hoofdinhoud
Part of the Lenovo G Series of everyday laptops released in November 2012.
23 Vragen Bekijk alle
My machine won't regulate processor thermal heat
Hi i'm Leslie,
Ive got a lenovo g580, i3 with 8GB RAM running on Windows 10 (v1511) ,
my main problem is the Processor Thermal.
I tested my machine with the Intel Processor Diagnostic Tool 64bit latest version, managed to pass everything else but failed with the following error :
Entering run forever
1 degrees C below maximum
Test Result - FAIL
Expected Greater than 1 degrees below max
Received 1 degrees below max
Test FAILED
Please check your Processor Thermal Solution
Kindly help us with a solution for the problem because its been making my machine shut down unsuspectedly without notifying. This has caused instability when i'm working throughout the day.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Is the CPU fan running? Are the vents clear and unobstructed? Use Task Manager to see what % the CPU is running at. If high % and you are not doing much on the laptop, check what applications or processes are using the CPU the most and why
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Leslie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 268
