Howsoever/Whatsoever the “success” may be, the “Boot-Loop” issue should NOT be there. The fact that it is there means that the “Expensive-Smartphone” Buyer is being some sort of unpaid guinea-pig for “LG”.
“High-Five-ing” and similar resolution means The Lacking of Wisdom, Wisdom being an innate quality “Provisioned-Within” ALL. Wisdom enables The-Individual NOT to be “Stupid-Dumb”/Addicted to Wrongfulness. You know, when you know it is wrong but is unable to counter/”address” the wrongfulness.
Just because some methodology “works” for you does not mean it will work for another. Correct or not ? If correct, which it is, why paid over-the-odds for something NOT Smart at all - other than making The “Easy-Go” but “Hard-To-Comeby” unpaid cheering “High-Fiver” cheering for “The Likes of LG” and their methodology of making unpaid guinea-pigs via A Very Expensive “Smartphone” purchase..
24 opmerkingen
I have LG G4 of which PCB main has been replaced just recently. I bought that fone in Fiji and after using for 6 months one day it automatically shutdown and never restarted. My fone was under warranty for a year so i took it to the seller. They sent it across to New Zealand for repair and i received my fone back after 6 weeks. Currently I am using it and not sure how long it will last.
door Mohseen Khan
It is a manufacturing fault in lg g4 models i disassembled mine and used a hair dryer to heat it up and works for a couple of minutes and dies again. Replacing new board may resolve the issue however it may go on bootloop again.
door khurram iqbal
I had the same problem as you guys. my warranty just lapsed few days ago and got the problem of boot loop. they advise me to replace the motherboard but i guess it is not acceptable and the problem will still occur even you replaced the motherboard. the only resolution is to recall all LG G4 customers and replace it with G5 if that has no problem like G4. if we talk about satisfaction, they can only get a score of 1 because this should not suppose to happen in the first place. it's manufacturer's problem then recall it. I hope LG people realize the fact that we bought the phone as we seek satisfaction and not disatisfaction.
door cgonzales0508
All the LG G series suffer from either thermal throttling issues or devices bricking for no aparrant reason.
door Ben
I was lucky enough to have mine go into bootloop 10 days after the guarantee expired. Now I'm on my own and it is not feasible to spend 190usd to fix the phone. LG should recall these phones or give a solution as it is a manufacture problem. At least Samsung replaced the note 7 without hesitation.
door Epten Lepi Decko
19 commentaren meer tonen
