New motherboard does not recognize USB
Replaced the motherboard and everything worked fine until the battery died. It was not charging while I had it plugged in. Now it is dead and will not take a charge and boot. There is no visible damage to the connector or wire from the USB/sound board. Does something on the board have to be reset for it to recognize the USB/ sound board?
Is dit een goede vraag?
What is the history of this tablet? Did you find out what was wrong on the previous motherboard?
door Ben
The device stopped booting one day and I tried to flash the os but made a mistake and blanked the recovery partition. It was done till I replaced the motherboard then it came back like a champ. I reinstalled my apps and set it up. By then the battery was low and I plugged it in but it did not show it was charging by the outlet or through the computer. It did not recognize any power or PC connections. I hoped it was charging anyway and left it plugged in for the night. The next day it was completely dead. There is no way I could have damaged the connector from the USB/sound board since I barely had to touch it to move the new motherboard in or out. That was a very easy install. Unless there just happened to be a weird Static discharge that I didn't see .... Not sure if I now have to order the USB/sound board plus shipping or if there is a hidden jumper pin to pair the battery to the motherboard. Any ideas?
door michael lemacks
Have you tried another battery?
Edit: Actually it sounds like charger port if it's not detecting the charger or the computer.
door Ben
Did you figure out what was wrong? My problem is similar.
door Charlie Hindman
