Ga door naar hoofdinhoud
De Toyota Matrix (officieel de Toyota Corolla Matrix genoemd en niet te verwarren met de Hyundai Matrix) is een compacte hatchback die door Toyota wordt geproduceerd en is afgeleid van de Toyota Corolla.
How to replace a door check stop?
How do I replace a door check stop on my 2003 Pontiac Vibe?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
I am having the same problem with my 2010 Vibe. In the first place it is a factory defect that you have to remove the inside of the door in order to get the door stopper out. It should have been made so that a person would only have to remove the bolts and the stopper would slide out. This is utterly ridiculous that a person has to remove the inside of the door! I am in the process of cutting the hole bigger in the door and using different bolts and then installing the door stop from the outside. The dealers want $235 plus tax per door stop! This is totally an outlandish price!!! Toyota wants $158 for the door stop on a Matrix which should be identical parts! But I am not going to pay those kinds of outlandish prices!!! I am going to try to glue a piece of brass onto the little plastic piece that used to rub on the arm as brass will last a lot longer than the original plastic piece, especially on our gravel roads when dust and grit gets in there and acts like sandpaper. If that doesn't work I will make a spring loaded thing to rub on the arm. BUT I AM NOT GIVING THE DEALER A THOUSAND DOLLARS FOR FOUR LOUSY LITTLE DOOR STOPS!!!! (All four are worn out in 200,000 kms)
Was dit antwoord nuttig?
Voeg je antwoord toe
robertdetchon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 1,389
