Ga door naar hoofdinhoud
Introduced November 2012, this is a capable desktop computer with an Intel Core i7 3770S quad-core processor, 12GB of RAM, and a 3TB hard drive. It has a 23 inch, 1080p touchscreen and integrated Beats Audio.
Why is my computer not turning on?
My computer is not turning on the a/c adapter makes a noise and light blinks but the monitor will not power on I have purchased a new a/c adapter thinking it would resolve this issue and that did not fix the problem any ideas of what I can do?
Is dit een goede vraag?
Score 3
1 Opmerking
Computer ENVY 23 not turning on blank screen ! HELP
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Is there a hdmi port or a dvi or vga that you can hook it up to an external monitor to see if it will work that way ? this will tell if the screen itself is the problem . You may also want to try removing one stick of ram at a time to see if the issue is with the ram.
HP Envy 23-d060qd TouchSmart RAM Replacement
You could also try doing a static discharge. Unplug the computer and then hold the power button down for 60 seconds then plug it in and try to boot
. Hope some of this is helpful
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Yes, the static discharge option works with this type of machines.
door
Voeg je antwoord toe
Anayeli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 7,090
