Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
My battery life drain on standby
what is the different between
ic u2
and
ic power
what's the problems for both ?
my problem battery life drain on standby even after battery replacement ..
I'm sure it's hardware problem
any idea
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
ic u2 functions is management the data transfer, charge, and boot
ic power functions is supply power to all ic
battery drain common there are have short on the machine ic or capasiotrs
Was dit antwoord nuttig?
1 Opmerking:
Can you tell me what should i replace to fix battery drain
door
Iphone 5s.Have the same issue after battery replacement, find a temporary solution.
when Disconnected Home button flex cable from logic board, battery drain stopped.
Tried many different home buttons but when connected battery draining started again.
Actually I also changed home button and charing socket nothing changed. The phone still draining battery while on standby except home button flex cable departed from the socket.
Couldn't find different solution
Any idea what the problem is?
Voeg je antwoord toe
Omar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 221
