Ga door naar hoofdinhoud
Repair guides and troubleshooting support for Leapfrog LeapPad3 Learning Tablet
My speaker and D-Pad are simultaneously not working.
The speaker is fuzzy and sometimes does not have any sound at all. Only one or two of the directions on the D-pad are registering. I'm looking for a way to resolve the issue without replacing either component.
Is dit een goede vraag?
Score 2
1 Opmerking:
My Leappad won't let me press my name on my Leappad.
door
Voeg een opmerking toe
1 Antwoord
I had the same problem with my LeapPad3. Always turn off your device and turn it back on again, as this can solve a few issues your device is having. If this doesn't work, you will have to remove the back cover of the device and tighten the cable connecting the speaker to the motherboard. If that doesn't fix the problem, then you may be forced to replacing the speaker itself. There is a guide 'here' that can help you through the process step-by-step. Good luck!
Was dit antwoord nuttig?
Voeg je antwoord toe
Matt Irvine zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 336
