Device won't hold a charge, what do I do?
When the charger is plugged into the device the device works fine but when plugged out it dies shortly after.
Is dit een goede vraag?
If the device turns on when the charging cord is plugged in, but immediately shuts off when you disconnect the device. Then, I believe that you may have a faulty battery, since the charging port and cable appear to be working properly. I would recommend looking into replacing your battery.
Was dit antwoord nuttig?
If you need more assistance I would recommend checking out the DKnight MagicBox II Troubleshooting Guide
I'm having the same issue, and at first glance I can't find an easy way to pop the speaker open. Where are the screws hiding?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 2,401
1 Opmerking
Where I can Buy a Battery for a Big Magic Box???
door djelvis20
