Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
How to Transfer Data Contacts from iPhone 5S to iPhone SE?
I am planning to buy the upcoming iPhone SE to replace the old iPhone 5s,now I wondering does anyone can help me transfer all contacts, messages and other data from old iPhone 5s to iPhone SE with iTunes/iCloud, I have searched in the Apple App Store and can’t found any app supports transfer contacts between two iPhones. Is there any way to copy contacts, call logs, messages, and more data from iPhone 5s to iPhone SE directly? Please help!!!!!!!
Is dit een goede vraag?
Score 4
4 opmerkingen
Well, to transfer contacts from iPhone 4s to iPhone SE, if you don't want to use the traditional cumbersome method, Phone Transfer can help you transfer contacts and more from old iPhone to new iPhone directly,it supports copy contacts between two different models of iPhone even they are not in the same version of iOS( ios 6, ios 7, ios 8, ios 9 and later).Now,you can use this phone transfer program to copy contacts from iPhone 4s, iPhone 5s, iPhone 5 to new iPhone SE. What’s more,if you use Android mobile phone before,you can use this phone to phone transfer to copy contacts between android and iPhone safely and conveniently. You can also transfer other data from old iPhone to new iPhone,such as text messages, photos, videos, call logs,ect.
In additions, you can also use this program to restore data backup to your new iPhone, including the backup of KIES, iTunes, iCloud, BlackBerry, OneDrive, etc.
Read more from: https://www.youtube.com/watch?v=C7SsLSGG...
Hold this can help you, best regard!
door
New iPhone SE is in iOS 9.3 operating system, and you can use iCloud or third-part app to easily transfer contacts from old iPhone to new iPhone. Of course iCloud could be the 1st choice for you if you want sync all of contacts.
door
Now iPhone X and iPhone 8 are coming out, are your ready for switching to them, if yes, you need know how to transfer data from your old phone to iPhone X and iPhone 8, here you can refer to Coolmuster iOS Assistant.
door
Backing up takes one day or more!
I was verry happy with my XMass present a iPhone 8.
I used my wifes Mac to backup my 5s, message not enough space, moved some big files to the external drive, still not enough space.
Ok, next thing backup to iCloud, not enough space, buy more, thats what I did.
iTunes does not see my iPhone 8, Google it, download the newest version iTunes 12.7.2 for macOS.
After downloading.......Ai..... this version does net work on your Mac.
I am not buying a new Mac just to get my 8 working.
So, back up the 5s to my new bought iCloud space.
Backing up takes 50 minutes, some time later 2 hours, 17 hours, one day.
So I stopped.
Uptill now I loved Apple, use it already more than 20years for filmedditing, but now I really don't know what to to and think.
I now setup my 8 as a new phone, but I need some files and photos from my 5s on my 8.
Who can help me out of this circkle.
Happy New Year.
Henri.
door
Voeg een opmerking toe
12 Antwoorden
Het nuttigste antwoord
Hi
When you connect your iPhone to iTunes backup your data and then plug in the new iPhone and restore the data.
Hope this help
Was dit antwoord nuttig?
Score 5
1 Opmerking:
Yep, no apps needed. Just backup your phone to the computer, and when connecting your new phone choose to restore the backup of your old phone rather than setting it up as new. You will have everything from your old phone on the new phone
door
You can use iTunes, iCloud, as well as other professional data transfer tool like which introduce as above. There are no doubt that some professional data transfer tool is more powerful, effective, time-saving and easy to use.
Score 1
1 Opmerking:
Hello, restoring a backup to your new iPhone SE is a good way to transfer call history, messages, contacts and more from iPhone 5s to iPhone SE. But you cannot choose the selected items to get transferred, and some unwanted data may also be transferred to your iPhone SE. To avoid this, you can try an iPhone to iPhone Transfer Tool like AnyTrans, and here is a tutorialhttps://www.imobie.com/support/transfer-...
door
Hi Rolutry ,
Have you used the iTunes or iCloud to backup your iPhone 5s contacts or any other data?Maybe you can transfer the data to your new iPhone SE with the iTunes.
Or you can have a try with the software iSkysoft Phone Transfer which is my friend recommended to me. I have tested in my iPhone 6, just one click can solve your problem. The picture below is the interface of the software, it is clear to see that you just need to select the contactd , the call logs or other contents then click the Start Copy button.So easy and so useful!
Score 1
Turn on contacts in iCloud, and sign in iCloud on your new phone, that's it.
For full transfer, turn on everything in iCloud settings, connect to wifi and charge overnight should do the trick.
I don't see why this can be so difficult.
Score 1
1 Opmerking:
@tomchai, the problem with this solution is limited space.
door
I know more from this post to sync contacts to iPhone in different situations. In fact ,want to sync contacts between iPhone is relatively easy. It is so difficult to sync messages ,photos,videos .Google contacts ,and facebook can help sync contacts between two phone devices.
Score 1
my iPhone 5s was stolen and blocked so got I phone se my old iPhone got found so how can I transfer details from blocked iPhone 5s to I phone se
Hello! Two way can solve it. One is using iCloud, if you have iCloud account, you just log in it in SE, you can sync the contacts which have been synced in 5S. Another way is use a program named iOSToto. It allows connect two iOS devices at the same time. Then you can use it tranfer iPhone data easily.
In this case, Coolmuster Phone Transfer is what you need. With which you can easily transfer data between two iPhone in a few clicks. It is designed to transfer all your data in just one click, including music, photos, videos, contacts, messages, and more in just one click.
I have the iPhone se and want to transfer everything to my iPhone 6s. I understand from reading these comments to transfer data, pictures and contacts BUT how do I keep the same phone number? Is this something I can transfer on my own or do I need my carrier at&t to do that? And what about the SIM card ?
1 Opmerking:
The phone number is attached to the SIM card. Simply use a paper clip to open the SIM card slot on both phones (its on the side and you will see a pin hole. Move the SIM card from the SE to the 6S. The 6s needs to be either unlocked or an AT&T / Verizon model.
door
As you can see on 3uTools, you can easily click on Migrate Data.
You can check this tutorial: How to Transfer Data from one iPhone to another iPhone?
Comme vous pouvez le voir sur icloud shield, vous pouvez facilement cliquer sur Migrate Data. Vous pouvez consulter ce tutoriel: comment debloquer un iphone bloqué icloud
Well, I had this problem before. I want to change my old iPhone SE to iPhone 7 because my old iPhone is not working well. But as I reflect, I was thinking if I can transfer all my data to my new phone since every bit of data on my old phone (especially on WhatsApp) are very important to me. So, I researched and found the solution to my problem. I've read this article https://echoshare.co/transfer-whatsapp-h... and tried the solution they offer, and it worked like magic!!!! gosh. Sharing this to you, this might help you :)
Voeg je antwoord toe
rolutry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 18,913
