Where to order pebble steel Battery replacement
Anybody knows where to get a replacement for the pebble steel battery?
Is dit een goede vraag?
I googled the fullriver battery company in China and found and found this page where they picture the original Pebble. http://www.fentbattery.com/en/Cylindrica...
After a little poking around their site I got to this chart:
http://www.fentbattery.com/Upload/201605...
I haven't cracked open my Pebble steel to measure the battery yet, but I did google a couple of the model numbers like this : "043030C battery". This resulted in a string of China import sites (aliexpress, dhgate, etc) that offered to post me one of these.
I guess if you are willing to measure your battery dimensions, and order the corresponding battery from china you could finish up with a cheap replacement battery. I haven't tried it yet, buy have a depleted battery too by the looks, so interested in how you get on. Who knows you might even manage to squeeze a 300mAh battery in and get 14days out of your pebble?
Was dit antwoord nuttig?
I didn't need to solder. The connector on board is fine, but it's just friction (and a piece of foam glued to the back) that keeps the cable seated in the connector. So my tearing was just the cable partially unseating.
I never had the classic, but my issue was intermittent and for a while I was convinced rebooting the watch made a difference; kinda seemed to. There's forum threads that claim memory leak causes the tearing.
I don't think so. The Pebble Time products have completely different chassis dimensions and motherboard shap; I believe they're thinner for example. The chassis dimensions and motherboard shape affect how much space there is for the battery.
There are teardowns for the Pebble Time products; you should look at those to get some idea. You might have to disassemble your Pebble Time and use calipers to measure your existing battery. If you do that, please add that info to the relevant teardown article specific to your product. Also note which Pebble Time product you have. The Time Round, Time Steel, and Time (plastic chassis) are all different external dimensions and most likely have different batteries.
I have brand new pebble steel, unfortunately it was sitting in my drawer for 4 yrs, now it is not charging, it was bought in best buy vancouver, display only appears when charge cable is attatched, plz help me find a working solution..
Model is 401B, (6EE9)
Sr No Q206115EO1JY
tariqniazi@gmail.com
I buy Pebble Steels in this condition by the dozen. They appear to have had a problem with their original battery supplier, given the number of Steels that are in like-new condition but with swelled batteries.
Here's the typical behavior: Plug in the charging cable and the display activates, and the watch works as long as external power is applied. The one thing that usually doesn't work is Bluetooth - turning BT on draws too much current and the watch reboots. Remove the charging cable and the display instantly blanks.
One fix is a replacement battery. The battery that works for me is the 402020, available on eBay for about $10. Other batteries may work, but this one has worked fine for me and provides 4-5 days of normal, connected use from fully charged to 20%.
If you don't have the tools or skills it's probably cheaper to buy a refurbished Steel on eBay. They're available for $25-$50 with a fresh battery and fixes to other common Pebble Steel problems, like defective zebra strips.
I found Pebble to very unhelpful with the issues I've had with my Pebble Steel. Since it was out of warranty, they could not provide ANY kind of service for the watch. All indications were that the battery was depleted. After several email exchanges, they pointed me to this site. I still need to find a replacement battery for my watch. I know that Pebble will not be a source; Does anyone have a supplier who sells the battery for the Pebble Steel at a reasonable price?
If you find out which is the exact (or better) replacement battery that will retrofit into the Pebble Steel please let me know via the forum right here.
Thank you.
If anyone has measurements for the battery i will try ordering one from aliexpress.
http://www.fentbattery.com/en/Cylindrica... lists a 402222S 3.7v 130mAh at 3.9mm x 21.5mm x 21.0mm. The ifixit.com teardown photos show the battery has 402222 printed on the front and the back says 130mAh, so this is probably the same battery.
Thanks alot Paul! I have messaged two vendors on aliexpress now. One had alot of small 3.7 batteries, not the 402222 but they had a 302222. Ive also messaged another vendor who had "fullriver" batteries .
My pebble steel is having some tearing issues which may be the flex or some water damage. So a teardown is overdue, might as well replace the battery while I'm at it.
I tore mine down about a year ago to fix screen tearing. I put a couple of pieces of business card between the back of the case and the screen connector to apply pressure to it. Has worked like a charm! Tearing Solved! (Just like this: http://goo.gl/N3bHPQ)
But my battery is down to only about 2-3 days per charge. I ordered a 402020 from Aliexpress (160mAh). They claim 4mm20mm20mm so I really hope it fits. I'll find out in 30 days, I guess.
Jupp, 402020 is what the vendor told me to buy aswell.
My tearing is just like the classic stuff but it goes away when i press the buttons on the right.
Is the problem usually that the connector is loose on the board or on the flex? If I'm not able to solder it back on I'll do the pressure fix.
I replaced my battery today, my god the flex on the board was such a ##&&% to get back on. Had to remove the foam to get a good feel of the connector. No wonder that thing is causing tearing, i placed a melted layer of esd bags on top of it to keep it put. But so far i have no backlight and my charging led has gone dark.....
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 9,550
2 opmerkingen
Is it the same battery of the Pebble time?
door Dimas Caparros
No. The Pebble Time battery is slightly too big and has the wrong connector. I've had success with the 402020, available on eBay.
door Rich Stillman
