Ga door naar hoofdinhoud
The Samsung Galaxy J1, released January 2015, model number SM-J100VPP/SM-J100H.
107 Vragen Bekijk alle
Why does my samsunggalaxy j1 is not opening?
When i tryed starting up my samsung galaxy j1, it doesn't start up until the point that i can use it .. it is stucked at a samsung logo on my screen and keeps on repeating until my battery is dead. Before this happend, my phone says it lacks free storage and can't recieve more msgs. Then i restarted my phone and then this happened. Please help me guys. Really need my phone to be fixed as soon as possible
Is dit een goede vraag?
Score 24
9 opmerkingen
it will delete all my data stored in internal storage
please add solution if any alternative
door
My phone is not starting
Its only showing galaxy J1 ace and turning off it continues like this until remove the battery
It has been charge too but still the samething
Anyone can suggest what can be done
door
i tries the hard corde 2 times but it won't let me use it at all ? why it keeps showing verizon get ready to enjoy/ Then iat the bottom it says lets get started emergency call and don't activate?
door
Please he LP me my Samsung Galaxy j1 is not working how to restore firmware...
door
My sumsung j1 do the same just shows log then went off again and again
door
4 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Samsung logo then off and does it again?
Try leaving it on charge for half an hour if that does not work you may need to do a factory reset or reload the software on the phone in order to get it working again.
To factory reset:
Hold power button + volume up + home button until Samsung logo appears. When Samsung logo appears stop holding the power button but continue holding the other buttons. Once you get into a recovery menu which usually release all keys.
Use volume keys to navigate the menu and the power / home key to select the highlighted option.
Do wipe data / factory reset. Wait for this to complete and reboot phone.
If this still doesn't solve the problem then you will need to restore firmware using Samsung Kies / Samsung Smart Switch.
Or flashing firmware via Odin via this guide:
http://updato.com/how-to/how-to-install-...
Was dit antwoord nuttig?
Score 9
11 opmerkingen:
how to restore firmware using samsung kies?
door
how am i able tp restore the firmware on my phone(samsung galaxy j1 ace)
door
,how to restore the firmware using my phone Samsung Galaxy J1
door
What if after factory reset, it still doesn't work?
door
Sir how to repair my samsung j100 its stack showing the logo samsung and it wont even start stack at showing the logo
door
6 commentaren meer tonen
i try this Hold power button + volume up + home button but it doesn't work, how to restore firmware using samsung kies?
Score 2
4 opmerkingen:
It's still it doesn't work to open my galaxy j1
door
Please help me to open my galaxy j1... thank u
door
Sir can u help me my Samsung j100 dead boot from logo until i restore finish not flushing need fix ty
door
Can I buy board of Samsung j100
door
Try to establish a healthy charging regimen so that your battery doesn't learn to die.
My screen still shows “SAMSUNG” and won’t even turn off
1 Opmerking:
Need my phone urgently because of health problems
door
Voeg je antwoord toe
Ac zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 61
Altijd: 56,921
